Balbes писал(а):хлебнул (набрался) воздухом - поэтому не хватает давления на ХХ
stanislav писал(а):Думаю, что мужскому началу больше соответствует
FLUID REPLACEMENT (POWER STEERING)
1.Raise the front wheels on a jack, and then support them with rigid racks.
2.Disconnect the return hose connection.
3.Connect a vinyl hose to the return hose, and drain the oil into a container.
4.On vehicles with a patrol engine, disconnect the high tension cable. On vehicles with a diesel engine, remove the fuel cut valve connector attachedto the injection pump.
While operating the starter motor intermittently, turn the steering wheel all the way to the left and right several times to drain all of thefluid.
5.Connect the return hoses securely, and then secure it with the clip.
6.Fill the oil reservoir with the specified fluid up to the lower position of the filter, and then bleed the air.
Specified fluid : PSF-III
