ENGINE PACKAGE - VGT REGULAR ENG
FACE LIFT MODEL - 1'ST F/LIFT
RAD CORE MATERIAL - RESISTANT CACL2
T/C CAUTION LABEL - ENGLISH
EMISSION REGULATION - EURO 4
EURO EM(W/O EOBD)
UNDER COVER - W/O NOISE PAD
BATTERY CAPACITY - 100AH (20HR)
BATTERY SAVER
AT KNOB - LEATHER WRAPPED
6 POSITION - BLACK
CLUTCH LOCK
H-MATIC
T/F TYPE - ELECTRONIC
INDEPENDENT - 6 SIZE
SEMI FLOAT'G - 7 SIZE
AL WHEEL 7.0JJ * 16 - B TYPE
245 TIRE - 245/70 R16
TIRE SOURCE - HAN KOOK
HUB CAP - B TYPE
FULL SIZE 1EA - AL WHEEL & TIRE
TIRE PRESSURE LABEL - AUSTRALIA
TOOL SET & JACK LABEL - AUS+NEW ZEALAND
FR SUSP TYPE - D/WISHBONE+COIL SPRING
S/ABSORBER TYPE - CONVENTIONAL VALVE
STABILIZER BAR
RR SUSP TYPE - 5-LINK COIL SPRING
STABILIZER BAR
4-SPOKE - LEATHER
STEER'G COLUMN-MANUAL UPR TILT
DRIVER SIDE - DEPOWERED
PASSENGER SIDE - DEPOWERED
CURTAIN A/BAG
PAB ON/OFF SWITCH
HPS(HYDRAULIC POWER STRG)
FR BRAKE - DISC-16 INCH
ABS (ANTI LOCK BRK SYS)
TANDEM BOOSTER - 8+9 INCH
HIGH GRADE
INSIDE HNDL OVER RIDE - DRIVER SIDE ONLY
CHILD SAFETY RR DR LOCK'G
IMPACT SENS'G AUTO DR UNLOCKG
IGN KEY REMINDER
FUEL FILLER DR REL TYPE - ELECTRIC
SINGLE TILT'G & SLID'G - POWER-NORMAL
TAIL GATE O/SIDE HANDLE - NATURAL COLOR
TAIL GATE FINISH'G-FORMED TYPE(PLASTIC)
WINDOW TRIM
IGNITION ILLUMINATED - BULB TYPE
KEYLESS ENTRY-PANIC
DR FRAME MLDG - BLACK
CENTER TRIM - ARTIFICIAL LEATHER
FR DR GLASS - TINTED
RR DR GLASS - TINTED
P/WINDOW SW DR'S - WOOD GRAIN(A TYPE)
P/WINDOW SW PA'S - WOOD GRAIN(A TYPE)
P/WINDOW SW RR SIDE - WOOD GRAIN
FINISH'G - BODY COLOR
MAP POCKET-FR DR
POWER WINDOW(FR+RR)
AUTO DOWN - DRIVER SIDE
FOOT REST - METAL
FR - ASH TRAY W/ ILLUM
CIGAR LIGHTER - W/ ILLUM
W/ LOCK
CUP HOLDER - FR(W/O ILL)
W/ STORAGE BOX ARM REST - DLX(2 DIN)
POWER OUTLET
LID TRAY - TRAY BOX-FLOCK'G
GRAIN - WOOD GRAIN
RR(W/O ILL)
MATERIAL - CLOTH(STD)
VANITY MIRROR - NON GLASS TYPE
VANITY MIRROR COVER
ILLUMINATED
SUNVISOR TYPE - SLIDING TYPE
VANITY MIRROR COVER
ILLUMINATED
ROOF TRIM MATERIAL - CLOTH(STD)
RR - 2 EA
RR - 2 EA
RR P/TRAY MATERIAL - W/PAPER
LUGGAGE NET HOOK
LUGGAGE NET
LUGGAGE SIDE LH
LUGGAGE UNDER FLOOR BOX
DR SCUFF - PLASTIC TYPE
LUGGAGE SIDE BOX
W/S GLASS TYPE-TINTED (W/ S/BAND)
A TYPE - CR COAT'G
GRADE - GLS
ANTI-CORROSION TREATMENT
ID PLATE - GEN+MES TYPE(ID)
RR STEP PLATE
БАГАЖНИК НА КРЫШЕ
MUD GUARD-RR
W/ WIPER DEICER
BACK LITE GLASS TYPE -TINTED(W/ HEATED)
RR HEATED W/ TIMER
H.M.S.L - T/GATE OTR
PASS'S SIDE - ELECTRIC HTD-CONV
DRIVER'S SIDE - ELECTRIC HTD-CONV
COLOR - BODY COLOR
GARNISH-SIDE - BODY COLOR
MLD'G-ROOF - BLACK
RR QTR GLASS TYPE -TINTED
FR FLAT TYPE - FR FULL FLAT
HEAD REST - UP/DOWN & SLIDING
DOUBLE RECLIN'G
ADJUSTER - HEIGHT ADJUSTER
LUMBAR SUPPORT - MANUAL
ACTIVE HEAD RESTRAINT
SEAT BACK PNL(W/POCKET)
SEAT WARMER(HEATER)
SLIDING
DOUBLE RECLIN'G
SEAT UNDER TRAY
SEAT BACK - SEAT BACK PNL(W/POCKET)
SEAT WARMER
DRIVER'S SIDE - ELR
PASSENGER'S SIDE - ELR
RETRACTOR PRETENSIONER - ELECTRICAL TYPE
PRE TENSIONER - ELECTRICAL TYPE
SEAT BELT REMINDER
LOAD LIMITER
S/BELT ANCHOR - ADJUSTABLE
LOAD LIMITER
6:4 SPLIT BACK FOLD'G - CUSHION+BACK
CTR
HOLDER - UPR ANCHOR
SIDE - ELR
CTR - ELR
W/O BOX
PROJECTION-LOW BEAM-A TYPE
SPORTY TYPE - MFR
INTEGRATED - CLEAR LENS
CONVENTIONAL - CLEAR LENS (ON FENDER)
RR COMBI LAMP - NON LED TYPE
FR - W/ SUNGLASSES
CTR - GLOW LAMP
FR - LAMP
RR - LAMP
CARGO LAMP
BULB TYPE - 2 BULB
W/ SUNROOF SW
SPEEDOMETER
ТАХОМЕТР
FUEL
WATER TEMP.
LCD ODO/TRIP METER
A/T POSITION INDICATOR
DIRECTION INDICATOR
OIL PRESSURE
BRAKE OIL
PARK'G BRAKE
DR AJAR - DR AJAR
BATTERY CHARGE
HIGH BEAM
LOW FUEL
RR FOG LAMP
TRUNK LID(T/GATE) OPEN
CHECK ENGINE
РЕМЕНЬ БЕЗОПАСНОСТИ
А.Б.С
A/BAG
A/BAG OFF INDICATOR
CRUISE CONTROL
RR HEATED GLASS
FR FOG LAMP
GLOW INDICATOR
4WD ENGAGED
IMMOBILIZER
SPEEDOMETER TYPE - KMPH
TEMPERATURE UNIT - C
FREQUENCY-SMART KEY - GENERAL
RADIO+CASS+EQ+CD+MP3 - M 455
FREQUENCY VIBRATION - AM9K/FM50K
ANTENNA TELESCOPIC - POWER
SPEAKER LOCATION FR DR - GENERAL
SPEAKER LOCATION QUADRANT INR COVER
SPEAKER LOCATION RR DR LOW-GENERAL
РЕМЕНЬ БЕЗОПАСНОСТИ
DR AJAR
FUNCTION - AIR FILTER
FUEL FIRED HEATER
ELEC TYPE - SOFT TOUCH TYPE
RR HEATING DUCTS - 2ND SEAT
FR COOLER - FULL AUTO A/CON
FR COOLER - DUAL FULL AUTO A/CON
RR WIPER - INTERMITTENT(NON VARIABLE)
EURO EM(W/O EOBD)
BATTERY SAVER
6 POSITION - BLACK
CLUTCH LOCK
H-MATIC
HUB CAP - B TYPE
STABILIZER BAR
STABILIZER BAR
4-SPOKE - LEATHER
CURTAIN A/BAG
PAB ON/OFF SWITCH
HIGH GRADE
IGN KEY REMINDER
WINDOW TRIM
KEYLESS ENTRY-PANIC
MAP POCKET-FR DR
POWER WINDOW(FR+RR)
FOOT REST - METAL
W/ LOCK
POWER OUTLET
GRAIN - WOOD GRAIN
RR(W/O ILL)
VANITY MIRROR COVER
ILLUMINATED
VANITY MIRROR COVER
ILLUMINATED
RR - 2 EA
RR - 2 EA
LUGGAGE NET HOOK
LUGGAGE NET
LUGGAGE SIDE LH
LUGGAGE SIDE BOX
A TYPE - CR COAT'G
GRADE - GLS
RR STEP PLATE
БАГАЖНИК НА КРЫШЕ
MUD GUARD-RR
W/ WIPER DEICER
RR HEATED W/ TIMER
COLOR - BODY COLOR
MLD'G-ROOF - BLACK
DOUBLE RECLIN'G
SEAT WARMER(HEATER)
SLIDING
DOUBLE RECLIN'G
SEAT UNDER TRAY
SEAT WARMER
DRIVER'S SIDE - ELR
SEAT BELT REMINDER
LOAD LIMITER
LOAD LIMITER
CTR
HOLDER - UPR ANCHOR
SIDE - ELR
CTR - ELR
W/O BOX
SPORTY TYPE - MFR
FR - W/ SUNGLASSES
CTR - GLOW LAMP
FR - LAMP
RR - LAMP
CARGO LAMP
BULB TYPE - 2 BULB
W/ SUNROOF SW
SPEEDOMETER
ТАХОМЕТР
FUEL
WATER TEMP.
LCD ODO/TRIP METER
DIRECTION INDICATOR
OIL PRESSURE
BRAKE OIL
PARK'G BRAKE
DR AJAR - DR AJAR
BATTERY CHARGE
HIGH BEAM
LOW FUEL
RR FOG LAMP
CHECK ENGINE
РЕМЕНЬ БЕЗОПАСНОСТИ
А.Б.С
A/BAG
A/BAG OFF INDICATOR
CRUISE CONTROL
RR HEATED GLASS
FR FOG LAMP
GLOW INDICATOR
4WD ENGAGED
IMMOBILIZER
РЕМЕНЬ БЕЗОПАСНОСТИ
DR AJAR
FUEL FIRED HEATER
