top.mail.ru
Technical Service Bulletins (TSB) - Тех. бюллетени
Различная документация по автомобилю KIA SORENTO
Сообщение DrFOX » 26 окт 2008, 19:48
TSB - 2002
BBD-P030-FY - Sunroof removal & installation and Motor initialization.
BBD-S086-FLFYFSFX - Model Plate, Misprinted
BBE-P058-FY - Deletion of the back glass switch connector
BBE-S059-FY - Introducing Super Lock System
BCH-P36-FY - The new addition of A/S part number
BDS-S101-FYBDS-S101-FY - Sorento Oversteer
BEE-S087-FY - Hard Starting or Black Smoke or Hard Acceleration
BEE-S099-FY - Evaporative Canister Accessibility
BEM-S108-FYFJ - Cylinder Head Gasket
BGI-S063-FYBGI-S063-FY - Sorento Trailer Hitch Point
BSS-P024-BL - Changes in Lower arm ball joint tightening bolt torque
BST-S090-FY - Steering Wheel Rattle Noise
BST-S095-FY - Service Action for Electric Power Steering Gear
BBE-P067-FY - Change of the Motor for the Sun Roof system
BEM-P070-FY - Change of the timing chain cover and mounting bolt
BSS-S111-FY - Lower Arm Spindle
BSS-S119-FY - Lower Arm Spindle(Revised)
BST-S117-FY - Service Action for Power Steering Connecting Bolt
DrFOX
FAQ-модератор
Доп. информация: Чип-Тюнинг
Re: Technical Service Bulletins (TSB) - Тех. бюллетени
Сообщение DrFOX » 26 окт 2008, 19:57
TSB - 2003
CBD-P068-FY - Change of the Hood opener release type
CBD-S003-FYFL - Hood Panel Anti-Rust Treatment
CBD-S004-FY - Hood Panel Anti-Rust Treatment
CBD-S48-FY - Sorento Repair Guide for Door Checker Noise
CBE-P016-FY - The correction of the cluster type
CBE-P056-FY - New application for digital clock and rheostat connected
CBE-P058-FY - Detailed inner circuit diagram of the power seat (driver’s side)
CBE-P059-FY - Inspection of the FIS (Front Impact Sensor) connector
CBE-P079-FY - Deletion of the pins on AQS
CDS-S039-FY - Limited Slip Differential of Sorento
CDS-S088-FY - Service action for front differential Oil seal
CEE-S012-FY - Checking procedure of APS module ( Case Study )
CEE-S019-FY - Service Action for Engine Wire and Hanger Bracket Interference
CEE-S041-FY - Blower Wire-harness and V-belt Interference
CEE-S073-FY - Service tip for Sorento Water Leakage
CEM-P051-FY - Information for SST of 2.5 C/R engine
CEM-S011-FY - Introduction of New SST-Fuel Pressure Pipe Socket Wrench
CEM-S024-FY - Oil Relief Valve Spring Replacement
CEM-S031-FY - Inspect Cam Position Sensor
CEM-S034-FY - Oil Relief Plunger & Spring Replacement (Revised)
CEM-S076-FY - Replacement cooling system
CFL-P103-BL - Change Of Sorento Diagnostic Trouble Code System
CMT-S054-FY - Difficult gear shift of manual transmission
CSS-P006-FY - Change of the front wheel guard
CST-S036-FY - Steering Wheel Rattling Noise for Sorento
Последний раз редактировалось DrFOX 25 ноя 2009, 18:02, всего редактировалось 2 раз(а).
Причина: Добавлена информация
DrFOX
FAQ-модератор
Сообщение DrFOX » 26 окт 2008, 20:02
TSB - 2004
DEM-S081-FY - Safety Recall: Pulley-Alternator/Generator Replacement
EEM-S002-FY - Sorento Engine Coolant Reservoir improvement
DST-S107-FY - Service Campaign for Engine MIL On
DAT-P020-FY - Wiring Diagrams Of Automatic Transmission Control System And Instrument Cluster
DAT-P026-FY - Wiring Diagrams Of Automatic Transmission Control System And Instrument Cluster (Correction Of Tsb Dat-P020-Fy)
DAT-P048-BL - Automatic Transmission Cable Adjustment Procedure
DrFOX
FAQ-модератор
Сообщение DrFOX » 09 ноя 2008, 18:34
TSB - 2005
KT2005120201 - Service Campaign: Sorento Digital Clock Losing Time (SC041)
KT2005110201 - 3.5L Sigma Engine Assembly Tip
KT2005100501 - Sigma 3.5L Engine Spark Plug & Ignition Coil Inspection Procedure (Engine - 022)
KT2005100401 - Recall Campaign: 2003 Sorento Fuel Line Replacement (SC052)
KT2005091301 - Service Campaign: 2005 Sorento LX Wheel Guard Replacement (SC043)
KT2005062702 - Sorento Seat Track Position Sensor DTC Related Improvements (Body - 029)
KT2005061605 - 2005 2WD Sorento Driveline Shudder During Acceleration With Automatic Transmission
KT2005022519 - Intermittent Hard Steering: Vehicles Equipped with EPS Only (Chassis - 011)
KT2005022512 - 3.5L Sigma Engine Cylinder Block Damage (Engine - 015, Revised) (INACTIVATED 2007-02-19)
KT2005022402 - Evaporative Canister Service (Fuel System - 003)
KT2005022362 - Service Campaign: Seat Belt Buckle Wire Harness (SC029)
KT2005022357 - Rear Defogger Fuse (Electrical - 007)
KT2005022354 - Sorento Battery Replacement (Electrical - 005)
KT2005022118 - Jack Protector Pad and Retaining Strap (Body 025)
DrFOX
FAQ-модератор
Сообщение DrFOX » 15 ноя 2008, 23:48
TSB - 2006
KT2006032601 - Canister Close Valve Inspection/Replacement (Fuel - 011)
KT2006042501 - 2003~2006 Sorento Crankshaft Bolt (3.5L) Torque Guidelines (UPDATED 2007-08-13) /Обсуждение.../
KT2006042605 - Внесение изменений в конструкцию форсунки омывателя заднего стекла
KT2006042610 - Замена кронштейна троса переключения режимов работы автоматической коробки передач
KT2006051005 - Раскодирование серийных номеров (VIN)
KT2006051509 - Обновление Программного Обеспечения Комплекса Hi-Scan Pro, Касающееся Функции Проверки Двигателя
KT2006060708 - Специальный инструмент для снятия форсунки системы впрыска топлива двигателя с общим нагнетающим трубопроводом
KT2006060805 - Изменение В Конструкции Форсунки Омывателя Заднего Стекла (№ Уточняемого Бюллетеня: Kt2006040704)
KT2006061404 - Конденсат в фарах
KT2006071204 - Попадание воды в фары при погружении(all)
KT2006071804 - Замена болта крепления крышки головки блока цилиндров двигателей типа SIGMA(GH),(BL)
KT2006071809 - Замена нижней крышки ресивера-осушителя кондиционера(SA),(MG),(VQ),(BL)
KT2006071905 - Устранение задевания рулевого вала жгутом основной электропроводки(BL)
KT2006090104 - Руководство по эксплуотации прибора для проверки системы вспрыска типа COMMON RAIL, предназначенного для дизельных двигателей стандарта EURO-IV
KT2006090504 - Проверка уровня жидкости автоматической коробки передач(all)
KT2006090708 - Обращение с прокладкой пробки сливного отверстия моторного масла(all)
KT2006091404 - Диагностика утечки масла из рулевого механизма с гидроусилителем(BL)
KT2006092205 - Инструкция по обслуживанию динамика(all)
KT2006101204 - DTC P1638 - датчик скорости автомобиля Sorento(BL)
KT2006102404 - Transfer Replacement - Vibration During Turning /Замена раздаточной коробки при вибрации на повороте при малых оборотах/
KT2006111315 - Новый зажим переходника для манометра измерения компрессии цилиндров Sorento(BL)
KT2006112704 - Шум цепи механизма газораспределения и от взаимодействия выпускного коллектора с другими частями Carnival(VQ),Opirus(GH),Sorento(BL)
KT2006112804 - Утечка моторного масла из уплотнений задней крышки Sorento
KT2006120105 - Изменение номеров деталей расширительного бачка
KT2006120701 - Sorento Transmission Shift Hesitation (Trans/Drive - 017) (Updated 2007-01-17)
KTU2006111001 - Заміна термостату /Обсуждение.../
DrFOX
FAQ-модератор
TSB - 2007
KCR07-92-P020-BL - Провод соединения с "МАССОЙ" подогреваемого переднего сиденья пассажира
KGR07-11-P010-GHVQVQBL - Замена узла стартёра и его крышки
KGR07-41-P010-BL - Обновление схем проводки с целью удаления вакуумного датчика тормоза
KT2007010504 - Системы COMMON RAIL проверка на утечку топлива
KT2007011004 - Самопроизвольное переключение на 5-ю передачу
KT2007020511 - Undesired Shift Into 5Th Gear
KT2007020804 - Процедура замены лампы подсветки регулятора обогревателя
KT2007021404 - (Измененный №KT2006101001) Указания по транспортировке – Предупреждение повреждения вакуумного насоса
KT2007022319 - Удаление датчика влажности
KT2007030204 - Изменение процедуры снятия цепи механизма газораспределения
KT2007031914 - Замена узла лампы освещения салона
KT2007040401 - Sorento/Sedona Throttle Position Sensor W/3.5L Engine (Fuel System - 013) (Updated 2007-05-14)
KT2007040504 - (Обновленный технический бюллетень № KT2007021301) Самопроизвольное переключение на 3-ю или 5-ю передачу
KT2007040601 - Front Seat Belt Guide Rattle (SC067) (Updated 2007-05-02)
KT2007050205 - Замена датчика положения дроссельной заслонки в СИГМА-Двигателях
KT2007051706 - Замена дефлектора в ЛАМБДА-Двигателе
KT2007052204 - Изменение емкости аккумуляторной батареи для ЛАМБДА-Двигателя
KT2007060104 - Сброс оборотов двигателя SORENTO(BL)-3.5 Л
KT2007062704 - Неисправность вентилятора – замена силового моп-транзистора
KT2007070901 - Sorento Crankshaft Bolt Replacement (SC072) (Updated 2007-08-13) /Обсуждение.../
KT2007071201 - 2007 BL Sorento, Noise Under Vehicle when Pulling Out
KT2007071810 - Изменение процедур устранения неисправностей по диагностическим кодам неисправности в руководствах по ремонту
KT2007071901 - Sorento Compressor Disc & Hub Replacement (Climate Control - 011)
KT2007072604 - Замена болта шкива коленчатого вала /Обсуждение.../
KT2007073101 - Sorento (BL) Coolant reservoir Replacement (Engine - 034)
KT2007080804 - Замена болтов крепления заливной горловины топливного бака
KT2007081503 - 2003-2006 Sorento (BL) Manual HVAC Head Bulb (Climate Control - 009)
KT2007081504 - A/C compressor Disc & Hub/Pulley/Field Coil Assembly Inspection and Replacement Procedure (Climate Control - 012) (Updated 2007-09-05)
KT2007081604 - Инструкция по замене колеса датчика скорости системы ABS
KT2007082204 - Инструкция по обслуживанию для замены датчика температуры испарителя автомобиля SORENTO (BL)
KT2007090409 - Добавление сиденья с электроприводом и системы иммобилайзера для автомобиля SORENTO(BL) 2008
KT2007092401 - Sorento (Bl) Automatic Transmission Shift Knob (Trans/Drive 020)
KT2007110509 - Замена болта шкива коленчатого вала /Обсуждение.../
KT2007110604 - Составные компоненты узла аудиосистемы
KT2007111505 - Дополнительное уведомление о цветовом коде для Sorento, нового Sportage и Cerato
KT2007120501 - 2007 BL Sorento with Torque On Demand (TOD) Shudder
DrFOX
FAQ-модератор
Сообщение DrFOX » 27 окт 2009, 01:55
TSB - 2008
KCE08-92-P310-BL - OUTSIDE REARVIEW MIRROR REPLACEMENT (замена зеркала с разборкой обивки двери)
KGR08-31-P130-PUKMBL - Смазочный ниппель внутри универсального шарнира карданного вала
KCR08-14-P100-BL - Замена болта хомута форсунки
KCR08-14-P102-BL - Замена болта хомута форсунки (Измененный бюллетень KCE08-14-P101-BL)
KGR08-14-P050-BL - Новый топливный фильтр для замены установленного на автомобилях SORENTO (BL) 2002-2006 модельных годов
KCR08-12-P021-BL - Замена подузла индукционного клапана управления (Новая редакция бюллетеня KCE08-12-P020-BL)
KFR08-12-P121-GHVQBL - Повышенный шум от натяжителя цепи привода распределительного механизма двигателей
KFR08-13-P010-VQGHBL - Включение контрольной лампы проверки двигателя с появлением кода неисправности (DTC), связанного с пропусками зажигания и (или) неисправностью кислородного датчика
KFR08-13-P011-VQGHBL - Включение контрольной лампы проверки двигателя с появлением кода неисправности (DTC), связанного с пропусками зажигания и (или) неисправностью кислородного датчика
KFR08-31-P041-BL - Замена пакета муфты раздаточной коробки (Новая редакция бюллетеня KFE08-31-P040-BL)
KFR08-31-P042-BL - Замена пакета муфты раздаточной коробки (Новая редакция бюллетеня KFE08-31-P041-BL)
KFR08-31-P110-BL - Замена пакета муфты раздаточной коробки (Новая редакция)
KFR08-61-P010-BLUNMGJB - Повышенный шум в рулевом механизме
KFR08-71-P050-BL - Замена узла диска и ступицы компрессора кондиционера
KGR08-10-P010-al - Уведомление об изменении классификации технических бюллетеней по типам
KGR08-12-P050-BLGH - Замена комплекта для технического обслуживания масляного фильтра
KGR08-12-P070-GHBL - Уведомление о внесении исправлений - ТБ № KGE08-12-P050-BLGH
KCR08-91-P010-BL - Осмотр и замена держателя запасного колеса
KGR08-21-P010-al - Предупреждения по техническому обслуживанию датчика системы контроля давления в шинах
KGR08-31-P051-BL - Процедура технического обслуживания: замена узла раздаточной коробки (Новая редакция бюллетеня KGE08-31-P050-BL)
KGR08-31-P060-BL - Части раздаточной коробки, обслуживаемые отдельно
KCR08-12-P022-BL - Замена подузла индукционного клапана управления (Новая редакция бюллетеня KCE08-12-P021-BL)
KGR08-91-P990-BLLDUN - Уведомление о новых кодах цветов автомобилей 2009 м. г.
KGR08-91-P991-BLLDUN - (Новая редакция бюллетеня KGE08-91-P990-BLLDUN) Коды новых цветов автомобилей 2009 М. Г.
KGR08-92-P040-al - Предупреждения об установке компакт-дисков в CD-чейнджер
KT2008011403 - Замена фильтра топливного насоса
KT2008012801 - 2007 and later Sorento (BL) Cylinder Head Installation of Steel Ball Oil Passage Plugs
KT2008020601 - 2003~2006 Sorento Lower Induction Manifold Replacement Due to Anti-Rattle Clip or Bushing Failure / Vacuum Leak
KT2008021801 - 2008 Sorento Updates
KT2008052101 - Sorento ICV Replacement (Campaign - 073 (SC073))
KT2008061801 - 2007~08 Sorento Rear Wheel Guard Noise
KT2008091701 - Sorento (BL) Transmission Range ‘D’ Indicator in IP
KT2008092501 - Tire Pressure Monitoring System
DrFOX
FAQ-модератор
Сообщение DrFOX » 27 ноя 2009, 16:52
TSB - 2009
KRR09-41-P070-KMUNBLVQ - ЗАМЕНА ВЫКЛЮЧАТЕЛЯ СТОП-СИГНАЛА(TSB No. In English : KRE09-41-P070-KMUNBLVQ)
KGR09-92-P070-al - ПОСТАВКА НОВОЙ ДЕТАЛИ КРИВОШИПА ЭЛЕКТРОДВИГАТЕЛЯ СТЕКЛООЧИСТИТЕЛЯ(TSB No. In English : KGE09-92-P070-al)
KGR09-71-P071-al - (НОВАЯ РЕДАКЦИЯ)ЗАМЕНА ПРИВОДА КОМПРЕССОРА КОНДИЦИОНЕРА(TSB No. In English : KGE09-71-P071-al)
KGR09-71-P070-al - ЗАМЕНА ПРИВОДА КОМПРЕССОРА КОНДИЦИОНЕРА(TSB No. In English : KGE09-71-P070-al)
KGR09-31-P051-BL - (ПЕРЕСМОТРЕНО)ОТДЕЛЬНЫЕ КОМПОНЕНТЫ КАРДАННОГО ВАЛА(TSB No. In English : KGE09-31-P051-BL)
KGR09-14-P120-VQBLKMLDJBEDMGSA - (ПЕРЕСМОТРЕНО) КОНТРОЛЬНЫЕ ЛИСТЫ ДЛЯ РЕМОНТА АККУМУЛЯТОРНОЙ СИСТЕМА ПОДАЧИ ТОПЛИВА(TSB No. In English : KGE09-14-P120-VQBLKMLDJBEDMGSA)
KGR09-14-P010-LDBL - ЗАМЕНА КЛАССИФИЦИРОВАННЫХ ФОРСУНОК(TSB No. In English : KGE09-14-P010-LDBL)
KGR09-12-P241-BL - ЗАМЕНА КРЫШКИ ЦЕПИ МЕХАНИЗМА ГАЗОРАСПРЕДЕЛЕНИЯ НА ДИЗЕЛЬНОМ ДВИГАТЕЛЕ A-2.5L(TSB No. In English : KGE09-12-P241-BL)
KGR09-12-P240-BL - ЗАМЕНА КРЫШКИ ЦЕПИ МЕХАНИЗМА ГАЗОРАСПРЕДЕЛЕНИЯ НА ДИЗЕЛЬНОМ ДВИГАТЕЛЕ A-2.5L(TSB No. In English : KGE09-12-P240-BL)
KGR09-12-P200-al - МЕРЫ ПРЕДОСТОРОЖНОСТИ ПРИ ЗАМЕНЕ МОТОРНОГО МАСЛА И ДЕМОНТАЖЕ МАСЛЯНОГО ПОДДОНА(TSB No. In English : KGE09-12-P200-al)
KGR09-12-P100-BL - ЗАМЕНА УСТАНОВОЧНЫХ ШТИФТОВ И СКОБ КРЕПЛЕНИЯ ФОРСУНКИ НА ГОЛОВКЕ ЦИЛИНДРОВ ДИЗЕЛЬНОГО ДВИГАТЕЛЯ A-2.5L(TSB No. In English : KGE09-12-P100-BL)
KGR09-12-P062-JBEDLDTDMGGHUNAMKMVQBLHM - (НОВАЯ РЕДАКЦИЯ) ЗАТЯГИВАНИЕ БОЛТОВ БЕНЗИНОВОГО ДВИГАТЕЛЯ МЕТОДОМ МОМЕНТ ЗАТЯЖКИ / УГОЛ ПОВОРОТА(TSB No. In English : KGE09-12-P062-JBEDLDTDMGGHUNAMKMVQBLHM)
DrFOX
FAQ-модератор
Сообщение ShineOn » 24 июл 2010, 12:34
TSB - 2010
KCE10-14-E050-BL - Обновление программного обеспечения Блока Управления Двигателем для улучшения логики управления оборотами турбокомпрессора (TSB No. In English : KCE10-14-E050-BL) (1'206'960 байт)
То же, только ZIP-файл с полным списком VIN-номеров (4'145'013 байт)
Вернуться в Документация (BL)
