Классификация моторных масел по ACEA
Информация по разнообразным жижам, которые заливаются в агрегаты KIA SORENTO
Сообщение ShineOn » 17 фев 2009, 15:15
Классификация моторных масел по АСЕА, версия 2008 года (оригинал можно взять здесь)
Введение.
The ACEA 2008 European Oil Sequences for Service-fill Oils comprise 3 sets (classes) of sequences: one for Gasoline and Light Duty Diesel engines; one specifically for Gasoline and Light Duty Diesel engines with after treatment devices and one for Heavy Duty Diesel engines. Within each of these sets there are categories which reflect different performance requirements - four (A1/B1, A3/B3, A3/B4 & A5/B5) for gasoline and light duty diesel engines; four (C1, C2, C3, C4) specifically for engines with after treatment devices, and four (E4, E6, E7, E9) for heavy duty diesel engines. Typical applications for each sequence are described below for guidance only. Specific applications of each sequence are the responsibility of individual engine manufacturers for their own vehicles / engines.
The sequences define the minimum quality level of a product for self-certification to EELQMS and presentation to ACEA members. Performance parameters other than those covered by the tests shown or more stringent limits may be indicated by individual ACEA member companies.
NOMENCLATURE & ACEA PROCESS:
Each set of sequences is designated for consumer use by a 2 part code comprising a letter to define the CLASS (e.g. C), and a number to define the CATEGORY (e.g. C1). In addition, for industry use, each sequence has a two-digit number to identify the YEAR of implementation of that severity level (e.g. A1 / B1-04).
The CLASS indicates oil intended for a general type of engine - currently A / B = gasoline and light duty diesel engines; C = catalyst compatible oils for gasoline and diesel engines with after treatment devices. Other classes may be added in future if, for example, Natural Gas engines prove to require oil characteristics which cannot readily be incorporated into existing classes.
The CATEGORY indicates oils for different purposes or applications within that general class, related to some aspect or aspects of the performance level of the oil. Typical applications for each sequence are described below for guidance only. Specific applications of each sequence are the responsibility of the individual motor manufacturer for their own vehicles and engines. Oils within a category may also meet the requirements of another category, but some engines may only be satisfied by oils of one category within a class.
The YEAR numbers for ACEA Sequence is intended only for industry use and indicates the year of implementation of that severity level for the particular category. A new year number will indicate, for example, that a new test, parameter or limit has been incorporated in the category to meet new / upgraded performance requirements whilst remaining compatible with existing applications. An update must always satisfy the applications of the previous issue. If this is not the case, then a new category is required.
An administrative ISSUE Number is added for industry use where it is necessary to update the technical requirements of a sequence without the intention to increase severity (e.g. when a CEC test engine is updated to the latest version whilst maintaining equivalent severity; or where a severity shift in the test requires modification of the specified limits.).
Классификация («Consumer Language»)
A/B : gasoline and diesel engine oils
A1/B1 Stable, stay-in-grade oil intended for use at extended drain intervals in gasoline engines and car & light van diesel engines specifically designed to be capable of using low friction low viscosity oils with a high temperature / high shear rate viscosity of 2.6 mPa*s for xW/20 and 2.9 to 3.5 mPa.s for all other viscosity grades. These oils are unsuitable for use in
some engines. Consult owner manual or handbook if in doubt.
A3/B3 Stable, stay-in-grade oil intended for use in high performance gasoline engines and car & light van diesel engines and/or for extended drain intervals where specified by the engine manufacturer, and/or for year-round use of low viscosity oils, and/or for severe operating conditions as defined by the engine manufacturer.
A3/B4 Stable, stay-in-grade oil intended for use in high performance gasoline and direct injection diesel engines, but also suitable for applications described under A3/B3.
A5/B5 Stable, stay-in-grade oil intended for use at extended drain intervals in high performance gasoline engines and car & light van diesel engines designed to be capable of using low friction low viscosity oils with a High temperature / High shear rate (HTHS) viscosity of 2.9 to 3.5 mPa.s. These oils are unsuitable for use in some engines. Consult owner manual or handbook if in doubt.
C : Catalyst compatibility oils
C1 Stable, stay-in-grade oil intended for use as catalyst compatible oil in vehicles with DPF and TWC in high performance car and light van diesel and gasoline engines requiring low friction, low viscosity, low SAPS oils with a minimum HTHS viscosity of 2.9 mPa.s. These oils will increase the DPF and TWC life and maintain the vehicles fuel economy.
Warning: these oils have the lowest SAPS limits and are unsuitable for use in some engines. Consult owner manual or handbook if in doubt.
C2 Stable, stay-in-grade oil intended for use as catalyst compatible oil in vehicles with DPF and TWC in high performance car and light van diesel and gasoline engines designed to be capable of using low friction, low viscosity oils with a minimum HTHS viscosity of 2.9mPa.s. These oils will increase the DPF and TWC life and maintain the vehicles fuel economy.
Warning: these oils are unsuitable for use in some engines. Consult owner manual or handbook if in doubt.
C3 Stable, stay-in-grade oil intended for use as catalyst compatible oil in vehicles with DPF and TWC in high performance car and light van diesel and gasoline engines, with a minimum HTHS viscosity of 3.5mPa.s. These oils will increase the DPF and TWC life.
C4 Stable, stay-in-grade oil intended for use as catalyst compatible oil in vehicles with DPF and TWC in high performance car and light van diesel and gasoline engines requiring low SAPS oil with a minimum HTHS viscosity of 3.5mPa.s. These oils will increase the DPF and TWC life.
E : Heavy Duty Diesel engine oils
E4 Stable, stay-in-grade oil providing excellent control of piston cleanliness, wear, soot handling and lubricant stability. It is recommended for highly rated diesel engines meeting Euro I, Euro II, Euro III, Euro IV and Euro V emission requirements and running under very severe conditions, e.g. significantly extended oil drain intervals according to the manufacturer’s recommendations. It is suitable for engines without particulate filters, and for some EGR engines and some engines fitted with SCR NOx reduction systems. However, recommendations may differ between engine manufacturers so Driver Manuals and/or Dealers shall be consulted if in doubt.
E6 Stable, stay-in-grade oil providing excellent control of piston cleanliness, wear, soot handling and lubricant stability. It is recommended for highly rated diesel engines meeting Euro I, Euro II, Euro III, Euro IV and Euro V emission requirements and running under very severe conditions, e.g. significantly extended oil drain intervals according to the manufacturer’s recommendations. It is suitable for EGR engines, with or without particulate filters, and for engines fitted with SCR NOx reduction systems. E6 quality is strongly recommended for engines fitted with particulate filters and is designed for use in combination with low sulphur diesel fuel. However, recommendations may differ between engine manufacturers so Driver Manuals and/or Dealers shall be consulted if in doubt.
E7 Stable, stay-in-grade oil providing effective control with respect to piston cleanliness and bore polishing. It further provides excellent wear control, soot handling and lubricant stability. It is recommended for highly rated diesel engines meeting Euro I, Euro II, Euro III, Euro IV and Euro V emission requirements and running under severe conditions, e.g. extended oil drain intervals according to the manufacturer’s recommendations. It is suitable for engines without particulate filters, and for most EGR engines and most engines fitted with SCR NOx reduction systems. However, recommendations may differ between engine manufacturers so Driver Manuals and/or Dealers shall be consulted if in doubt.
E9 Stable, stay-in-grade oil providing effective control with respect to piston cleanliness and bore polishing. It further provides excellent wear control, soot handling and lubricant stability. It is recommended for highly rated diesel engines meeting Euro I, Euro II, Euro III, Euro IV and Euro V emission requirements and running under severe conditions, e.g. extended oil drain intervals according to the manufacturer’s recommendations. It is suitable for engines with or without particulate filters, and for most EGR engines and for most engines fitted with SCR NOx reduction systems. E9 is strongly recommended for engines fitted with particulate filters and is designed for use in combination with low sulphur diesel fuel. However, recommendations may differ between engine manufacturers so Drivers Manuals and/or Dealers should be consulted if in doubt.
Сокращения, использованные в тексте:
SAPS: Sulphated Ash, Phosphorus, Sulphur
DPF: Diesel Particulate Filter
TWC: Three way catalyst
HTHS: High temperature / High shear rate viscosity
ShineOn
Благодарил (а): 640 раз.
Re: Классификация моторных масел по ACEA
Сообщение ShineOn » 17 фев 2009, 15:18
А/В: масла для бензиновых и дизельных двигателей легковых автомобилей
A1/B1 Масла, предназначенные для бензиновых и дизельных двигателей легковых автомобилей и фургонов, допускающих применение масел, имеющих пониженную вязкость при высоких температурах и скоростях сдвига.
A3/B3 Масла с высокой стабильностью свойств, предназначенные для применения в высокопроизводительных бензиновых и дизельных двигателях легковых автомобилей и легких фургонов с удлиненными интервалами замены круглогодичного использования
A3/B4 Масла с высокой стабильностью свойств, предназначенные для применения в высокопроизводительных бензиновых и дизельных двигателях с непос­редственным впрыском топлива легковых автомобилей и фургонов, также подходит для применения, описанных в категории В3.
A5/B5 Масла с высокой стабильностью свойств, предназначенные для применения в высокопроизводительных бензиновых и дизельных двигателей легковых автомобилей и фургонов при увеличенных интервалах замены, допускающих применение масел, имеющих пониженную вязкость при высоких температурах и скоростях сдвига
С: масла, совместимые с каталитическими нейтрализаторами отработавших газов
C1 Масла с высокой стабильностью свойств, предназначенные для применения в высокопроизводительных бензиновых и дизельных двигателях с DPF* и TWC* легковых автомобилей и фургонов, допускающих применение масла с низкой вязкостью при высоких температурах и скоростях сдвига. Увеличивают ресурс катализатора нейтрализации отработавших газов типа TWC и фильтра DPF и обеспечивают экономию топлива
C2 Масла с высокой стабильностью свойств, предназначенные для применения в высокопроизводительных бензиновых и дизельных двигателях с TWC* и DPF** легковых автомобилей и фургонов, допускающих применение масла с низкой вязкостью при высоких температурах и скоростях сдвига. Увеличивают ресурс катализатора нейтрализации отработавших газов типа TWC и фильтра DPF и обеспечивают экономию топлива
C3 Масла с высокой стабильностью свойств, предназначенные для применения в высокопроизводительных бензиновых и дизельных двигателях с DPF* и TWC** легковых автомобилей и фургонов. Увеличивают срок службы фильтра DPF, катализатора TWC и обеспечивают экономию топлива
Е : масла для мощных дизельных двигателей грузовых автомобилей, автобусов
E4 Масла с высокой стабильностью свойств, обеспечивающие отличную чистоту поршней, эффективно снижают износ и препятствуют росту вязкости масла при накоплении сажи, устойчивы к старению. Рекомендуются для дизельных двигателей, удовлетворяющих требованиям Euro 1, Euro 2, Euro 3 и Euro 4, работаю­щих в особо тяжелых условиях. Обеспечивают удлиненный интервал замены согласно рекомендациям производителя двигателя. Подходят для применения в двигателях без фильтра твердых частиц выхлопа (DPF), для некоторых двигателей с рециркуляцией выхлопных газов (EGR) и оборудованных селективным катализатором нейтрализации отработавших газов NOx (SCR NOx). Соответствуют требованиям MB 228.5, MAN M3277
E6 Масла с высокой стабильностью свойств, обеспечивающие отличную чистоту поршней, эффективно снижают износ и препятствуют росту вязкости масла при накоплении сажи, устойчивы к старению. Рекомендуются для дизельных двигателей, удовлетворяющих требованиям Euro 1, Euro 2, Euro 3 и Euro 4, работаю­щих в особо тяжелых условиях. Обеспечивают удлиненный интервал замены согласно рекомендациям производителя двигателя. Подходят для применения в двигателях с и без фильтра DPF, в двигателях с нейтрализаторами SCR. Удовлетворяет требованиям двигателей работающих на малосернистом топ­ливе.
E7 Масла с высокой стабильностью свойств, обеспечивающие особо высокую чистоту поршней, предотвращают полирование стенок цилиндров, износ и образова­ние отложений в турбокомпрессоре; уменьшают рост вязкости при накоплении сажи; устойчивы к старению. Рекомендуются для дизельных двигателей, удовлетворяющих требованиям Euro 1, Euro 2, Euro 3 и Euro 4, работающих в особо тяжелых условиях. Обеспечивают удлиненный интервал замены согласно рекомендациям производителя двигателя. Применяются в двигателях без фильтров DPF, для двигателей оборудованных системой EGR и нейтрализаторами SCR.
ShineOn
Вернуться в ГСМ (BL)
