DrFOX
» 17 ноя 2008, 16:12
P0600(General) Communication Circuit Between ECM and TCM
Description
ECU commonly uses various information (engine RPM. Throttle opening, Torque Low Sensitivity Signal, etc) with TCU and uses these information for controlling the engine.
DTC Detecting Condition
1. IG key: ON
2. C019: CAN Communication Errors between ECU and TCU and between ECU and ABS and CAN Bus Error if no signal communication exists through CAN line.
P1616 Main Relay Control Circuit Malfunction
Description
The operating power for ECU, various actuators and sensors is supplied through the Relay which is controlled by ECU.
1. IG key: ON
2. C004 Main Relay Operation Time Error: If the main relay open or closes too early upon IG-On/Off signal, compare IG signal and micom signal of ECU.
3. C004 Main Relay Operation Time Error: If the main relay open or closes too late upon IG-On/Off signal, compare IG signal and micom signal of ECU.
сканер левый у твоих мастеров. Судя по расшифровке полетело главное реле...
